i cannot get my micrologix series a to connect to ignition.
is it because the subnet has been changed since the gateway is installed?
i can currently ping the ml1100 from the host computer.
any ideas??
any ideas??
sorry this is under the wrong topic
I was able to swap the ML1100 for a series B processor 1763-L16BBB Firmware 9 and it connected.
Has anyone else had a problem connecting to an older Micrologix series A firmware 3?
is this supported? or do i need to flash the firmware
You might try upgrading the firmware to series B, as the A only allows one ethernet connection.
