I have one Siemens PLC S7-1200 which easily be connected with Ignition now i am facing problem to connect Micrologix 1200 PLC serial port is available Can I connect Micrologix 1200 PLC with ignition without using NEt EN card
Unfortunately MicroLogix 1200 and 1500 devices are not fully supported. You are going to need to set Disable Processor Browse to True in your device connection settings in order to connect.
I think browsing is not supported in micrologix 1200 just like seimens plc 1200 I am facing difficulties because I don’t have serial port on my system and I want serial to ethernet convertor
You will need a bridge of some sort. Net-ENIs and Digi IAPs work.
