Microsoft Azure REST API - Authorization Rejection due to 'Content-Length'
Hello all,
I have encountered a problem when uploading files to an Azure BLOB Storage Account. More specifically, the ‘Content-Length’ parameter required in the Authorization Header (for the request) is unable to be computed dynamically. I am using the Component Upload component, and calling the event.file.getBytes() method to determine the ‘Content-Length’ parameter. The documentation that I have found indicates that this should in fact be the number needed to authorize the request. However, the Server response is a failure and returns a ‘Content-Length’ that does not match the one provided by Ignitions library method. Additionally, the amount by which they mismatch is not close enough to be a simple error. One troubleshooting thought I had was to try and read a file as bytes using a button event and ensure that the Component Upload is not returning an incorrect length. Does anyone have any suggestions as to what may be causing this issue?
Thanks,
Jonas
Have you seen this topic?
