Microsoft SQL Server on Linux with Ignition
Greetings all. I thought I'd share a small victory and also inquire as to whether anyone else has targeted any production deployments of MSSQL Server on Linux w/ Ignition. I just tried it out today and it worked just fine!
One thing that I found was that I couldn't use even the default instance name when connecting to my SQL instance on Linux. I had to omit it altogether:
This seems reasonable I suppose since I couldn't find SQL Server Browser listening on UDP 1434 like it would be on a Windows box. There is 1433/tcp and 1434/tcp, but no 1434/udp, which based on the link here (http://sqlmag.com/sql-server/sql-server-tcp-and-udp-ports) suggests is the SQL Server Browser port used for named instances.
Below is the output of netstat -lntu on my linux machine:
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:1433            0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:1434          0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:32000         0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:548             0.0.0.0:*               LISTEN
tcp6       0      0 :::8043                 :::*                    LISTEN
tcp6       0      0 127.0.0.1:45900         :::*                    LISTEN
tcp6       0      0 :::22                   :::*                    LISTEN
tcp6       0      0 :::8088                 :::*                    LISTEN
tcp6       0      0 :::8060                 :::*                    LISTEN
tcp6       0      0 ::1:4700                :::*                    LISTEN
tcp6       0      0 :::4096                 :::*                    LISTEN
udp        0      0 0.0.0.0:5353            0.0.0.0:*
udp        0      0 0.0.0.0:68              0.0.0.0:*
udp        0      0 0.0.0.0:33145           0.0.0.0:*
udp6       0      0 :::5353                 :::*
udp6       0      0 :::58984                :::*
udp6       0      0 :::4445                 :::*
udp6       0      0 :::55914                :::*
I'd be interested to hear any other folks interested in (or already) deploying SQL Server on Linux with Ignition. Exciting stuff!
The same problem, your solution worked.
