Millions of tags on a single server
Greetings everybody.
Our company is developing a very big Ignition solution for a customer with a complex architecture including several Gateways and several database servers distributed on different sites and considering security layers. We are using Perspective only.
The project is growing, and we expect that at a point we will have over 14MM Tags on a single layer, and we are discussing how many servers can handle this.
We received a recommendation from Inductive to consider a maximum number of 1.5MM tags on a single server.
In our case we have a gateway server (Back end) with 16 cores (virtual cpus) and 64 Gb of RAM memory that has 4.5 MM Tags. It works but not 100% error free. We think that it can handle this number of tags increasing cores and memory.
I want to ask for real life expertise about this. Can anybody share with us cores/memory of servers with millions of tags?
Thanks in advance!
This phrase should really show you that this:
Should be considered heavily.
Also consider supportability and maintenance:
If you have 14 million tags the plan of attack for organizing those should be well structured, so break down what tags make sense to be put together in those chunks of 1.5 to 2 million tags and divide it up that way.
I see you say backend server, but just to make sure I state this:
You should not have 1.5 million tags and perspective running on the same gateway. Or 4.5 million in your example. Utilizing a front-end and back-end gateway each (possibly multiple of each depending on number of screens and other factors) will also help handle load.
Don't put databases on the same server as Ignition either to help with performance.
I have found that with Ignition slamming a server with hardware capabilities doesn't always equal success. You have to architect out efficiency.
Thank you for the answer.
Yes of course, we have separate back end servers holding the actual tags, separate front end servers running the perspective, and separate servers running the databases.
My request for information is just for reference due that my customer wants to be sure that Ignition can handle such a big application, and also we want to have some reference prior to implementation in our testing environment.
So our decision right now can be lots of servers with less tags or few big servers with more tags.
I would recommend looking at Ignition Architecture Docs and reading more on the forum about Ignition architecture as there are plenty of conversations about it.
I am working on a large implementation for a food & bev manufacturer, and we are utilizing a structure similar to the scale-out.
Like I said, and IA recommends, you will need to manage the number of tags on each server as processing millions of tags from OPC takes time as well as tracking those tags in historian etc.
What does the MM multiplier signify or is it something else? A million would just be M. Is MM a million million = a giga?
Found this because I was curious as well:
MM (Millions) - Definition, Examples, What MM Means
Apparently, MM denotes roman numeral M (1000) multiplied by itself, thus 1 million
Blame it on the romans, if you must, but MM is used to denote million. M is the roman numeral for 1000.
It's used a lot in finances as well, so $1.4MM is $1,400,000.
Edit: Ryan beat me to it.
I haven't done a system that big but my experiences so far are consistent with what @Benjamin_Furlani said.
I would add that the number of tags a server can handle is one thing. The number of tags a PLC can handle based on the way you are updating them is another thing. Then you have other potential issues such as tags coming from AOIs if we're talking Rockwell tags, etc. There are a lot of variables and you should probably consider a pilot project to test out an architectural plan before you go crazy with it.
Not all tags are equal... for example, memory tags don't poll so they won't create the same kind of load on your architecture as polling tags do. Polling rates impact a lot at scale as well. Database tags have a much higher impact obviously.
I'm assuming you're already planning to use MQTT for security and streamlining the data transmission side of things. If not, look into it.
I don't know if it's because our windows servers have more IT scanning stuff going on or something else but I feel like our Linux servers can handle a lot more tags than our windows ones also.
@pturmel's knowledge reaffirmed
And I agree with Steve.
Never read the AOI instance (Although IIRC Phils driver does not have the same AOI reading issue, but I may be mistaken)
We make a UDT that is passed in as an In/Out that has only the data we would need to pull into Ignition and go from there.
Yes, never read tags from an AOI instance.
I'm trying to point you to some pitfalls so you hopefully don't step into it bigtime. It's bad to step it in. It's worse to step in it at scale.
Sorry
4.5MM is 4500000 tags
Not really. This is not new information for me.
Correct, as long as the AOI is not sealed with members with External Access=None.
Fair enough, I fixed my response :laughing:
