Hey, I am trying to use the system.tag.queryTagCalculation() to pull the minimum, maximum and average of a tag and have ran into some inconsistency.
- The Maximum Value is not matching the historical data (Station 9 State/Station 9 Valve)
Script Implementation:
Tag Binding
Transform the incoming value and return a result.
Arguments:
self: A reference to the component this binding is configured on.
value: The incoming value from the binding or the previous transform.
quality: The quality code of the incoming value.
timestamp: The timestamp of the incoming value as a java.util.Date
tag = [value["tag"]]
startDate = ""
endDate = ""
timeDiff = 0
if value["historicalMode"]:
try:
endDate = system.date.parse(value["endDate"])
startDate = system.date.parse(value["startDate"])
timeDiff = system.date.secondsBetween(startDate, endDate)
except:
endDate = ""
startDate = ""
if timeDiff>0 and value["historicalMode"]:
result = ScriptLib.DashBoards.analytics.getMinMaxAvg(tag, returnSize = 10,interval = 1,intervalUnit = "hr" ,jsonFormat = True, endDate = endDate,startDate=startDate)
type = 1
elif timeDiff <= 0 and value["historicalMode"]:
result = [{"Minimum":0,"Maximum":0,"Average":0}]
type = 2
else:
result = ScriptLib.DashBoards.analytics.getMinMaxAvg(tag, returnSize = 500,interval = 5,intervalUnit = "min" ,jsonFormat = True)
type = 3
return result
Script Library
def getMinMaxAvg(tags, returnSize = 100,interval = 1,intervalUnit = "hr" ,jsonFormat = True, endDate ="",startDate = ""):
#Set the interval to all lower case
log = system.util.getLogger("MinMaxAVG")
info = tags[0]
intervalUnit = intervalUnit.lower()
if endDate == "":
endDate = system.date.now()
if interval < 1:
interval = 1
if startDate == "":
if intervalUnit in ["hr","h","hours","hour"]:
startDate = system.date.addHours(endDate,-interval)
elif intervalUnit in ["sec","s","seconds","second"]:
startDate = system.date.addSeconds(endDate,-interval)
elif intervalUnit in ["min","m","minutes","minute"]:
startDate = system.date.addMinutes(endDate,-interval)
else:
startDate = system.date.addDays(endDate,-interval)
info = info+", Time - StartDate: " + str(startDate) + ", EndDate: "+ str(endDate)
data = system.tag.queryTagCalculations(tags,["Minimum","Maximum","Average"],startDate,endDate)
if jsonFormat:
data = ScriptLib.Framework.utility.datasetToJSON(data)
info= info +", Minimum: "+str(data[0]["Minimum"])
info=info +", Maximum: "+str(data[0]["Maximum"])
log.info(info)
return data
- When start and end dates are equal, perspective fails to load data and freezes the screens, I made a workaround for this issue.
Maybe I need to get the data and apply secondary min max average
