I’m trying to make a client open at a size of 800x70 but can’t seem to be able to get the designer to accept any value lower than 103?
After opening the client, I can manually resize to the height I want just fine, but want it to automatically open at that height. Am I missing something?
Under project properties - Client - Launching - Java Web Start Properties - I have the Width set at 800 and the height is set at 103. This is where the height will not accept a value lower than 103? I enter a lower value and when I press APPLY, it reverts back to 103.
Under user interface I have the minumum size set to 700x25
Hidding Menubar and Hiding Windows Menu.
Also is there a way to open in a windowed mode while also hiding the window title bar at the top of the client window?
Border Display Policy - Never
Title Display Policy - Never
The Dock Position is set to floating if that makes a difference?
Do these settings effect the main “Windows” project window? The project still shows the X to close the window, is still able to be maximized. Still shows the border and still shows the Titlebar?
What you want is the ‘Hide Menu Bar’ option. It’s under Project -> Properties -> Client User Interface. That’ll hide the menu on the main project’s window.
