Mitsubishi FX3U
Anyone successfully connected Ignition to Mitsubishi FX3U?
If so, what method did you use?
Most customers are using Kepware to connect to Mitsubishi PLCs right now.
Thanks, I will download a demo
Hi Emca, Have been successful data updating with Ignition and Kepware (FX3U)? Ignition works fine with Mitsubishi MX OPC server (GX Works2 simulator and PLC either way).
I tried to use Kepware, communication is ok, but Quality bad ( data not updating)…
hello.
now in version 8.1.31 support the FX3U??
regards
Yes, however you will need a FX3U-ENET module.
I tried to follow this configuration but its not working and this is for a different brand of SCADA, are these parameters also applicable to Ignition?
You will almost need to merge that configuration, have a look with the setup described in the manual, https://docs.inductiveautomation.com/display/DOC81/Mitsubishi+TCP+Driver#MitsubishiTCPDriver-FXConfigurator
Thanks, this solves it.
