Mixed Architecture Redundancy
Will Ignition redundancy work properly if the gateway is hosted on different CPU architectures: ARM64 master <-> x86_64 backup?
Based on the docs:
Setting Up Redundancy | Ignition User Manual
The CPUs shouldn't matter, but as stated in the blurb screenshotted below. Windows is recommended to be the master in mixed Operating Systems
I would expect so, as long as any folders spelled out in ignition.conf match up between the two systems. (OS matters more than architecture.)
