Hi
I’m having an issue with the mobile module which I cannot see to get sorted so any advice would be grateful.
The system is running Server 2008 Standard.
Ignition is version 7.6.4. (Latest release)
Java is version 7 update 25.
When trying to log into the mobile app via an iPad we are confronted with a " java.net.SocketException: Connection reset by peer. Socket write error"
The console is giving the following information: -
[size=85]11:22:33 PM DataServlet Failure in mobiledata/initvm
java.net.SocketException: Connection reset by peer: socket write error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
at java.io.BufferedOutputStream.flush(Unknown Source)
at java.io.DataOutputStream.flush(Unknown Source)
at com.inductiveautomation.mobile.gateway.MobileVMManager$ClientVMImpl.sendMessage(MobileVMManager.java:595)
at com.inductiveautomation.mobile.gateway.MobileVMManager.initializeVM(MobileVMManager.java:337)
at com.inductiveautomation.mobile.gateway.servlets.MobileSession.initializeVM(MobileSession.java:384)
at com.inductiveautomation.mobile.gateway.servlets.MobileDataServlet$InitVM.handle(MobileDataServlet.java:835)
at com.inductiveautomation.mobile.gateway.servlets.MobileDataServlet.doRequest(MobileDataServlet.java:159)
at com.inductiveautomation.mobile.gateway.servlets.MobileDataServlet.doGet(MobileDataServlet.java:108)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Unknown Source)
less
(I) 11:22:33 PM ClientVM Client vm d42aa7ab-6254-8bf0-5b2a-5b4cb66c18c1 closed: Exception during init message[/size]
It doesn’t seem to happen every time and once reset the system will log in fine.
I have trawled the forums and tried everything that has been said before but all to no avail.
Any ideas?
Kev
