Hi…
I’m trying to conect a Mobotix camera, i configured the mjpeg camera mode, but appear a error in the ignition windows “IOException:Stream is not an MJPEG stream”
Do you have any solution for that?
thx
Hi…
thx
The IP camera viewer only supports two video modes: MJPEG Stream and JPEG Stills. Make sure Mobotix can support one of these two. If so, you need to get the correct URL for the MJPEG stream.
Whats the URL that you are using???
I know that I have helped at least one customer successfully connect to a mobotix camera. You’re probably connecting to the wrong URL. I think the other customer ended up emailing mobotix to get help figuring out the MJPEG stream url.
