However, this seems to force all dropdowns to be modal. I have one particular list that is very long and would require a scroll bar on the modal popup, but there is no scroll bar.
If I comment out this style the scrollbar appears in the dropdown, but the dropdown only displays 4 items at a time, which is not ideal.
How can I create a secondary style for this long dropdown that would display a bunch of items and still allow a scroll bar?
Maybe try giving the specific dropdown that you require to have this max-height attribute a domID by adding it to the meta category on the component. Then you can style that specific domID using the similar CSS you have there.
Does this id need to be unique? If I have say 3 dropdowns that need that max height, can I assign them all the same id and apply the style to the one id, or do I need 3 unique ids?
edit:
I tried this with one dropdown, and it didn't seem to work, unless I've added the styling in the wrong place.
I think the problem is that the domId set in the meta category is for the dropdown box itself, not for the modal dropdown list. So, there's probably not a way to get to that dropdown from the component's domId.
Using Chrome to inspect this modal, I can't even find where the "max-height: 80%" is even applied in the CSS.
