SO, I have an address I need to read. The device is currently setup like this:
I only need to read 1 of the bits and it is one addressed "1.Reg0002.2"
Should I be able to delete all these addresses and only look for "1.Reg0002.2"?
Set an OPC tag like this:
ns=1;s=[UPS S]1.HR2.2
Anytime I delete any of these listings the tag gives me an unknown value error.
I think the prevailing advice is to NOT use the modbus address mapping. Use the full OPC path in the tag.
Modbus address mapping - Ignition - Inductive Automation Forum
Alright, so when I do use the modbus' addressing, that you set up in the device, I get this when using the OPC addressing method:
A good return of value.
Then when I do not use the modbus' addressing, that you set up in the device, I get this when using the OPC addressing method:
A "Unknown" return of value, stating that whatever was updating the tag doesnt exist.
Any ideas?
