Hello all.
I have connected to a device using OPC MODBUS RTU over TCP. I’m receiving good data for most of the points I need to bring into the SCADA but I have a question about splitting up a 16bit packed register. I need to read the high and low bytes. I believe what I need to do is first bring in the full 16bit register as a tag and then use an expression tag to perform the read function with an expression. My questions are:
- Is this a correct workflow?
- If so, does anyone know what the correct expression would be?
