Modbus Adressing Help
I am having trouble grabbing a Modbus address. i only need one point from it located at
"Modbus register 30521 (AI1) read from from the MOXA card"
the Modbus is set up and connected in OPCUA device connections but I cant seem to find a register where i am able to read a signal. i keep getting errors when i try and make tags.
also when i tried to use modbus addressing, the modbus didn't show up in the quick client.
I am using ignition edge if that effects anything.
Thank you
Try [devicename]1.IR521 or [devicename]1.IR520
Are you using a Moxa E1240 or similar?
If so see here: https://youtu.be/RDcFgat6_sc
That's 7.9 era but still relevant.
