Modbus import configuration
Hi guys,
Some problem with import Address Mapping for modbus configuration.
See please, what I’m doing wrong?
modbus-config.csv (15.5 KB)
Can you tell us what you think is wrong? I would suggest that the ‘Step’ value for each line is set to False as you’re only reading in one entry per line. Other than that it looks OK to me.
I agree, the CSV file looks correct. What problems are you having?
sorry for the silence. issue has been resolved, support answer:
You should be able to import the file up to 286 rows long. You may need to create a second logical connection to the same device for additional rows.
