Ok, I for some reason was getting bad quality on the first 100 words of the project. I figured this was a timing issue since I’m polling through a VPN tunnel right now, so I increased the timeout, and lowered the request size from 125 registers to 10. This seemed to work, but I was still getting bad quality for the first 20 words. This was weird because the quick client in the gateway showed bad quality for the tag, but clicking the [r] next to the tag for read would return the value and a good quality. Frustrated, I fired up a PLC simulator on my local machine to test what needed to be tested and I saw the same results. Deleting the device and recreating it with the same name got the same results. Creating a new device with a new name seemed to make things work correctly.
Any idea what happened for future reference?
