Modbus Poll Delay
How to Set Poll Day Delay in Ignition, I see it shows only communication timeout in Modbus settings. Is there any backend setting available for this poll delay.
If you are after a setting to configure the poll rate for modbus tags, you would set up the individual tags in ignition then assign them to a Tag Group. The tag group specifies the rate that the Ignition gateway polls the tags for values.
If you mean delays between commands, no, Ignition's Modbus driver doesn't have a setting for that. As it happens, my alternate driver does have this setting:
Thanks David, this should solve the problem..
-Hello, No I wanted to have poll delay for entire device only. Actually IFIX SCADA has this feature as well, to set poll delay for each register/register groups. With ignition same can be achieved as David_Stone suggested.
