Hello ,
Ignition version 8.0.1 and Ignition 7.9 (Both)
I am first time doing interface of PLC over MODBUS RTU over TCP in ignition . I am using Mitsubishi MT91 card for Modbus communication and verified Modbus communication with MODSCAN32 application . It is working perfectly fine , getting data over Modbus . But when I tired same interfacing with ignition , getting time out error. I increased thresholds also but getting same response . I changed configuration of 125 to 10 as I needed to read only 10 holding register from 400001 to 10 .
| Logger | Time | Message |
| TimeoutDaemon | 20May2019 12:55:49 | ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@302ed88b] request with key “java.lang.Object@2395d66e” failed due to timeout. |
| ReadHoldingRegistersRequest | 20May2019 12:55:49 | Request failed. FailureType==TIMEOUT |
| TimeoutDaemon | 20May2019 12:55:19 | ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@302ed88b] request with key “java.lang.Object@2395d66e” failed due to timeout. |
| ReadHoldingRegistersRequest | 20May2019 12:55:19 | Request failed. FailureType==TIMEOUT |
| ReadHoldingRegistersRequest | 20May2019 12:54:48 | Uncaught Throwable handling response. key=java.lang.Object@2395d66e, req=[ ], rsp=[ 01 03 00 00 00 ] |
| TimeoutDaemon | 20May2019 12:54:48 | ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@302ed88b] request with key “java.lang.Object@2395d66e” failed due to timeout. |
| ReadHoldingRegistersRequest | 20May2019 12:54:48 | Request failed. FailureType==TIMEOUT |
| ReadHoldingRegistersRequest | 20May2019 12:54:15 | Request failed. FailureType==DISCONNECTED |
| TimeoutDaemon | 20May2019 12:54:15 | ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@7222a9f7] request with key “java.lang.Object@2395d66e” failed due to timeout. |
Please help me !! thanks in advance !!!
