Modbus Swapped Float?
The device I am reading data from with the Modbus TCP driver uses a lot of swapped floats (2 16 bit words but swapped), any idea if that’s possible to read with the current Modbus OPC driver?
If you click “[edit]” in the device configuration area and then check “Show advanced categories?” you will see there is a boolean property called “Reverse Numeric Word Order”.
If you check this then all 32-bit values will have their words swapped, including floats. Unfortunately if you want only your floats swapped or only specific floats, this won’t work.
Perhaps he could create another connection to the device for just the floats?
