Modbus TCP configuration error
We are getting an error message on a tag after adding a this tag in a new project:
Error_Configuration(“Bad_NodeIdUnknown. The node Id refers to a node that does not exists in the server address space“)
Were can I find this Node Id?
That error is presumably on an Ignition Tag where you’ve specified an OPC Item Path that is not valid Modbus address syntax. The user manual describes the syntax in detail.
What’s the current OPC Item Path?
