I am having issues connecting to a fatek PLC over a modem.
I am able to connect to it when I test with my laptop on the machine.
But not over the network. I would appreciate guidance on where I should be looking at.
I am able to connect to other modbus and Siemens devices on the same switch but only this particular device is giving me trouble.
I think I found the issue, There was Layer 3 network connection between the PLC and my computer.
I was able to ping the PLC but could not get modbus tcp connection to it.
Interestingly enough I had a Siemens(connected through Ignition Siemens driver) and an Ezlogix PLC connected through modbus working through the same layer 3 network connection. It was only the Fatek PLC causing the issues.
I changed the connection to layer 2 and it worked.
