I created a screen that display values in modbus tags, when I removed the modbus device from our network. It freeze the screen and the designer. Also, I am not able to re-open the screen.
Got any idea?
Thanks in advance
[WARN] 9:36:08 AM ReadInputRegistersRequest Request failed. FailureType==DISCONNECTED
java.lang.Exception: Driver is disconnected.
at com.inductiveautomation.xopc.driver.api.AbstractDriver$RequestSchedule.cancelCurrentSchedule(AbstractDriver.java:1263)
at com.inductiveautomation.xopc.driver.api.AbstractDriver.notifyDisconnectDone(AbstractDriver.java:621)
at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.notifyDisconnectDone(AbstractIODelegatingDriver.java:71)
at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.disconnect(AbstractIODelegatingDriver.java:43)
at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.reconnect(AbstractIODelegatingDriver.java:93)
at com.inductiveautomation.xopc.drivers.modbus2.AbstractModbusDriver.access$100(AbstractModbusDriver.java:89)
at com.inductiveautomation.xopc.drivers.modbus2.AbstractModbusDriver$2.notifyCommunicationTimeout(AbstractModbusDriver.java:150)
at com.inductiveautomation.xopc.drivers.modbus2.requests.AbstractModbusRequest.fail(AbstractModbusRequest.java:158)
at com.inductiveautomation.xopc.drivers.modbus2.requests.AbstractModbusReadRequest.fail(AbstractModbusReadRequest.java:101)
at com.inductiveautomation.xopc.driver.api.ScheduledRequest.fail(ScheduledRequest.java:96)
at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.failRequests(BasicRequestCycle.java:337)
at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.run(BasicRequestCycle.java:293)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:317)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:150)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(ScheduledThreadPoolExecutor.java:98)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:204)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
less
[WARN] 9:36:08 AM ReadCoilsRequest Request failed. FailureType==TIMEOUT
java.lang.Exception: Request failed by TimeoutDaemon due to timeout: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadCoilsRequest@196487d]
more
[WARN] 9:36:08 AM TimeoutDaemon ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadCoilsRequest@196487d] request with key “1032” failed due to timeout.
[WARN] 9:36:05 AM ReadDiscreteInputsRequest Request failed. FailureType==TIMEOUT
java.lang.Exception: Request failed by TimeoutDaemon due to timeout: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadDiscreteInputsRequest@58f22b33]
more
[WARN] 9:36:05 AM TimeoutDaemon ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadDiscreteInputsRequest@58f22b33] request with key “1031” failed due to timeout.
[WARN] 9:36:02 AM ReadInputRegistersRequest Request failed. FailureType==TIMEOUT
java.lang.Exception: Request failed by TimeoutDaemon due to timeout: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadInputRegistersRequest@56179810]
less
[WARN] 9:36:02 AM TimeoutDaemon ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadInputRegistersRequest@56179810] request with key “1030” failed due to timeout.
[WARN] 9:35:59 AM ReadInputRegistersRequest Request failed. FailureType==TIMEOUT
less
[WARN] 9:35:59 AM TimeoutDaemon ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadInputRegistersRequest@56179810] request with key “1029” failed due to timeout.
