I am using Ignition to communicate with Mitsubishi PLC Q06 on Modbus Tcp/IP protocol.
I have configured all my tags as HRF13000 onwards. I can see these tags in OPC browser and they are all blue (i.e. no errors). But in my tag browser they r showing red false mark. I donr know why it is happening please guide me. I
I have checked PLC communication with ping command n it is good
There’s probably errors in your console of some sort - can you export and attach or email the logs.bin.gz file?
On the console page of the Ignition gateway there’s a link to export the logs.
Pls check uploaded logs file as requested by u
logs.bin.gz (352 KB)
The Mitsubishi PLC is returning an error code of 0x04 - Slave Device Failure in response to Ignition’s read requests.
Maybe you have the wrong unit ID set up for your configured addresses, or maybe the slave device is offline, or maybe it means something else (consult your PLC documentation…)
but some addresses are displayed blue in tag browser ok i will look into PLC manual for ur info
i m using Q10UDEH
not sure if this helps you but I always use a software like modbus poll to poll my modbus devices when I am doing initial configuration. its fast and easy to get connected and gives you many options on ordering your floating point data(if you are using floats). Its a very valuable tool and has saved me a headache on many occasions.
