I use a TM221 PLC Modbus TCP.
I can not read or write to an address.
The connection is OK but an error in the log.
ReadHoldingRegistersRequest Uncaught throwable handling response. key = 2 req = [], rsp = [00 02 00 00 00 06 00 03 00 00 00 02]
java.lang.ArrayIndexOutOfBoundsException: 0
at com.inductiveautomation.xopc.driver.util.OldByteUtilities.getInt(OldByteUtilities.java:143)
at com.inductiveautomation.xopc.driver.util.UAByteUtilities.getInt32(UAByteUtilities.java:120)
at com.inductiveautomation.xopc.driver.util.UAByteUtilities.getDataValue(UAByteUtilities.java:52)
at com.inductiveautomation.xopc.drivers.modbus2.requests.handlers.RegisterReadHandler.read32Bit(RegisterReadHandler.java:179)
at com.inductiveautomation.xopc.drivers.modbus2.requests.handlers.RegisterReadHandler.getValue(RegisterReadHandler.java:109)
at com.inductiveautomation.xopc.drivers.modbus2.requests.handlers.RegisterReadHandler.handle(RegisterReadHandler.java:83)
at com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest.handleResponse(ReadHoldingRegistersRequest.java:123)
at com.inductiveautomation.xopc.drivers.modbus2.requests.AbstractModbusRequest.receiveMessage(AbstractModbusRequest.java:158)
at com.inductiveautomation.xopc.drivers.modbus2.requests.AbstractModbusReadRequest.receiveMessage(AbstractModbusReadRequest.java:101)
at com.inductiveautomation.xopc.drivers.modbus2.requests.AbstractModbusReadRequest.receiveMessage(AbstractModbusReadRequest.java:59)
at com.inductiveautomation.xopc.driver.api.BasicRequestCycle.deliverMessage(BasicRequestCycle.java:184)
at com.inductiveautomation.xopc.driver.api.BasicRequestCycle.messageArrived(BasicRequestCycle.java:166)
at com.inductiveautomation.xopc.driver.api.AbstractDriver.messageArrived(AbstractDriver.java:708)
at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.messageArrived(AbstractIODelegatingDriver.java:110)
at com.inductiveautomation.xopc.driver.api.SocketIODelegate$DriverIOEventHandler$1.run(SocketIODelegate.java:177)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
If someone an idea of the problem.
thank you
