Hello,
Came across a printout of Modicon addresses that I need to create tags for in Ignition. They are assigned to the bit level of the word.
example:
40322/01
40322/16
How would I go about addressing this bit in a tag? I have tried the [Modicon,bit=1]HR322 format, and am getting very strange numbers (if the tag is an integer sometimes they are not bits).
Any help/explanation would be great.
Thanks!
Mike
That bit=X syntax is outdated and will be removed from the revamped user manual, whenever that happens.
Try using something like this and see if you get better results:
[Modicon]HR322.1
Thank you. (and thanks for getting back to me so quickly)
They seem to be behaving better. Still need to check some stuff out.
What was strange is that sometimes I would get results using the 400232/08 address format though.
If my address was 30033/01
I would use [PLC]N.IR33.1 ?
[quote=“mikehill100”]
I would use [PLC]N.IR33.1 ?[/quote]
Yeah, that looks correct, assuming N is the Unit/Slave ID.
