Modicon Modbus addressing
I’m working with a PLC programmer who is using a Modicon M241. I’ve never used the Modbus driver.
I have connected to it with the Modbus TCP driver, but all I’m having trouble getting to the correct addresses.
The addresses that I have been given by the programmer are %MW60200, %MW62200… and more addresses with this format. I’ve found some documentation that give me the some Modbus equivalents to %MW addresses, but not ones with this high of number.
Does anyone know how I can translate these to Modbus addresses? Or where I can tell the PLC programmer to look for them?
Thank you.
So are you saying that doing [Your Device Name]HR60200 on the item path of your Ignition tag is not working? This should be a standard address in Modbus.
No… I’m saying that I don’t know if HR60200 = %MW60200.
I’ll have the programmer put some data in there and see if it’s working.
Thank you for the reply.
Oh I see. If you look under the advanced tab in your device setup, there is a checkbox that says “One Based Addressing”. If you don’t seem to see the correct data, try changing that option. I have found that sometimes addresses are skewed by one in Modbus and changing this paramater will fix that skew.
(https://docs.inductiveautomation.com/display/DOC79/Connecting+to+Modbus+Device)
Great. I’m seeing most of the correct data, the addresses are skewed by one though.
Thanks a lot!
One that has incorrect data in it is a string that is address %MW60200.
If I set the ignition tag to HR60200 (or HR60201 to adjust for skew), is that only looking at a single 16 bit word?
If it is, how do I address it in ignition to read all of the string data?
Have a look at the string setup info, about halfway down on this page:
https://docs.inductiveautomation.com/display/DOC79/Modbus+Addressing
