Modified embedded view not updating upon browser launch
I have a page that shows the levels for several tanks, using an embedded view bound to tags. I created a new embedded view based on the original one and added a couple of sparklines. On my main view, I updated the path to the embedded view and synced the parameters. In designer, the sparklines are visible in both design and preview modes, however, when I launch a session from within Desinger, the sparklines do not show up until I hit refresh.
I closed all the open browsers and launched the application directly from the browser and I got the same result, the newly added sparklines do not show up until I hit refresh.
Hi @Ali.Etezadkhah,
This looks like something that would be best suited as a support ticket with our support department. They will be best suited to help you troubleshoot this issue. You can open a support ticket at https://support.inductiveautomation.com.
Regards,
