Modify data source script
This data source script looks at a nested query I have and generates a table that shows each step's name, start, end, and duration
	from system.report import QueryResults
	res = data["BatchInfo"].getCoreResults()
	data["BatchDuration"] = utils.prettifyMillis(system.date.millisBetween(res.getValueAt(0,"starttime"),res.getValueAt(0,"endtime")))
	steps = data["BatchInfo"].getNestedQueryResults().get("BatchSteps")[0].getCoreResults()
	for row in range(steps.getRowCount()):
		duration = utils.prettifyMillis(system.date.millisBetween(steps.getValueAt(row,"starttime"),steps.getValueAt(row,"endtime")))
		steps = system.dataset.setValue(steps, row, "duration", duration)
	data["BatchStepOverview"] = steps
(upload://8101yt0nU8M3E0SAKpQqn6HUuI0.png)
I need it to also return the following for each step:
the max temperature of the history tag "tt03 return temperature",
the min temperature of the history tag "tt03 return temperature",
The latest value of the final conductivity history tag "ae02 return conductivity"
Here are the Queries in the nested query group
Additionally, here are the names of the data sources I currently have
Here is my version of the script I have modified to attemp this. I think there are several issues, but I can't seem to pinpoint them.
	# Extract BatchInfo results
	data["BatchDuration"] = utils.prettifyMillis(system.date.millisBetween(res.getValueAt(0, "starttime"), res.getValueAt(0, "endtime")))
	# Get BatchSteps data
	# Iterate through steps
	for stepRow in range(steps.getRowCount()):
	    stepId = steps.getValueAt(stepRow, "stepid")  # Step ID for filtering phases
	    # Get BatchPhases for the current step
	    phases = data["BatchInfo"].getNestedQueryResults().get("BatchSteps")[0].getNestedQueryResults().get("BatchPhases")[stepRow].getCoreResults()
	    # Initialize variables for HiTemperature, LoTemperature, and FinalConductivity
	    hiTemp = None
	    loTemp = None
	    finalConductivity = None
	    # Iterate through phases
	    for phaseRow in range(phases.getRowCount()):
	        phaseId = phases.getValueAt(phaseRow, "phasenumber")  # Phase ID for filtering parameters
	        # Get BatchParams for the current phase
	        batchParams = phases.getNestedQueryResults().get("BatchParams")[phaseRow].getCoreResults()
	        # Process BatchParams to find HiTemperature, LoTemperature, and FinalConductivity
	        for paramRow in range(batchParams.getRowCount()):
	            tagAlias = batchParams.getValueAt(paramRow, "Data Key Alias")
	            value = batchParams.getValueAt(paramRow, "value")  # Assuming the 'value' column holds tag values
	            if tagAlias == "tt03 return temperature":
	                if hiTemp is None or value > hiTemp:
	                    hiTemp = value
	                if loTemp is None or value < loTemp:
	                    loTemp = value
	            elif tagAlias == "ae02 return conductivity":
	                finalConductivity = value  # Latest conductivity is the last value in this dataset
	    # Calculate step duration
	    duration = utils.prettifyMillis(system.date.millisBetween(steps.getValueAt(stepRow, "starttime"), steps.getValueAt(stepRow, "endtime")))
	    # Update step data with calculated values
	    steps = system.dataset.setValue(steps, stepRow, "duration", duration)
	    steps = system.dataset.setValue(steps, stepRow, "HiTemperature", hiTemp)
	    steps = system.dataset.setValue(steps, stepRow, "LoTemperature", loTemp)
	    steps = system.dataset.setValue(steps, stepRow, "FinalConductivity", finalConductivity)
	# Assign the processed steps dataset to BatchStepOverview
This returns the error
Feel free to follow up with any clarification that is needed.
Any help is greatly appreciated thanks
I ate some food and realized that I am vastly over complicating this, haha.
I should just be able to make a tag calculation query for that time range in the script.
Example
data = system.tag.queryTagCalculations(["[CIPSKID07]cip07/recipes/batch/tagdata/tt03 - return temperature"], ["Minimum", "Maximum", "LastValue"], steps.getValueAt(row,"starttime"), steps.getValueAt(row,"endtime"))
I will leave this post up if anyone ever comes looking
