Modify Translation
I'm using the system.util.modifyTranslation to modify some terms at the frontend. The modification are immediately updated into the designer translation manager but are only available in the perspective session after a save was done at the designer level.
Is this a normal behavior ? is there a way to force the reload of the translation terms via scripting or to save the project via scripting.
I'm on version 8.1.23 under ubuntu.
PGriffith has a module that has a function that allows you to script in a "system.project.save()".
(Not tried it myself, but description says "Essentially pressing the save button")
Is that what you are looking for?
hi @Richard_Giske,
i knew a saw this somewhere.
Thanks for the info
