Modify UDT type parameter via Gateway Script
Hi All,
very new to Ignition. Im trying to change UDT type parameter via Gateway script that is executed every second>
system.tag.writeAsync("[default]types/GW_ACV/Parameters.Reset", [1])
it doesn’t seem to do anything, Ive also tried tagConfigure with no success.
What am I missing ?
Parameters are not "live" the same way as tags, so do not propagate the same way. Use system.tag.configure() to alter a tag's configuration in a way that will restart the tag.
