Modifying a sql query dataset
Im returning a dataset to an xy chart with a sql query binding.
Im wanting to modify the incoming data for formatting. The first column is return a value of volt amps. Id like to divide the value by 1000 to return kva value. Also Id like to use the round function to keep it from 8 decimal places.
Is it possible to do this on a per column basis?
You can drop something like this in your project library, to call a transformation function on an entire column of a dataset as one operation.
Phil's Integration Toolkit module also probably has some neat capabilities here.
Appreciate this, can you give an example or point me in the direction of applying this function to a query binding?
