Modifying Voice Notification Language Profiles
Ignition 8.3-Perspective
It’s not clear to me how I edit what the TTS profile says during a voice notification. When I try to select any of the languages’ check boxes the toolbox tip says “Immutable resources cannot be edited.” When I select ‘Edit’ from the kabob, all the editable fields are grayed out.
Short answer:
Click whichever script(s) you care about and select 'Create Override' in the context menu:
Then create a new override in the core resource collection:
Then you'll be able to edit it as you expect.
Longer answer:
It's hard for us to convey this in the UI, but the new configuration model in Ignition 8.3 is basically a tree structure.
digraph Tree { rankdir=TB; node [shape=box]; edge []; External; System; Core; Dev; Test; Prod; Local; Actual [label="Live Config", style=filled, fillcolor=lightblue]; External -> System; System -> Core; Core -> {Dev, Test, Prod}; Dev -> Local; Local -> Actual; Test -> Local; Prod -> Local; }
It's essentially a single project inheritance tree, where the order is hardcoded.
What you do have control over is which deployment mode (if any) is loaded, and where you define resources.
You cannot, by definition, edit resources in system - they are provided by either the platform itself or a module. This includes the base call scripts. So what you have to do is "override" them, creating a duplicate in the core collection (or whichever deployment mode you have active, if you have one) that is then a "regular" resource you own and can modify as you wish.
Wow, thanks for the great explanation and information.
