My Ignition Module uses gRPC to send requests to an external server. In my gateway's build.gradle.kts I add the gRPC dependencies for version 1.70.0
dependencies {
// Ignition dependencies
implementation("com.inductiveautomation.ignitionsdk:ignition-common:${rootProject.extra["sdk_version"]}")
implementation("com.inductiveautomation.ignitionsdk:gateway-api:${rootProject.extra["sdk_version"]}")
compileOnly(project(":common"))
// gRPC and Proto
runtimeOnly("io.grpc:grpc-netty-shaded:$grpcVersion")
api("com.google.protobuf:protobuf-java:$protobufVersion")
api("io.grpc:grpc-protobuf:$grpcVersion")
api("io.grpc:grpc-stub:$grpcVersion")
api("io.grpc:grpc-core:$grpcVersion")
api("io.grpc:grpc-api:$grpcVersion")
compileOnly("org.apache.tomcat:annotations-api:6.0.53") // necessary for Java 9+
testImplementation("io.grpc:grpc-testing:$grpcVersion")
testImplementation("io.grpc:grpc-inprocess:$grpcVersion")
I initialize the gRPC service's ManagedChannel in the GatewayHook's startup.
I can build locally and run tests, but when I upload the .modl file I immediately get a fault with NoClassDefFoundError on the grpc code.
java.lang.Exception: Exception while starting up module "com.company.moduleName"
Caused by: java.lang.NoClassDefFoundError: io/grpc/StatusRuntimeException
Caused by: java.lang.ClassNotFoundException: io.grpc.StatusRuntimeException
As far as I can tell the jars are being built correctly.
./gradlew gateway:dependencies --configuration runtimeClasspath shows all the dependencies I'd expect.
I added a Main.java class and ran the code locally, and can successfully execute the gRPC requests.
Am I doing something wrong in the module build? Are the dependencies not being packaged correctly into the .modl? Or is it because something isn't loaded yet in startup? I'm fairly new to gradle, so I may have missed something obvious.
Using java17 and building for ignition 8.1.
