Module for Senting alarm pipeline messages to WhatsApp
Hello
I want to see my Alarms in WhatsApp.
Is there a module for sending the result of alarm pipelines to WhatsApp?
No, not currently, but if WhatsApp has an HTTP/REST API, it would be fairly easy to adapt the Slack Alarm Notification SDK example: https://github.com/inductiveautomation/ignition-sdk-examples/tree/master/slack-alarm-notification
In the ignition side, how would ignition use the SAN-SDK? I mean, how do you configure ignition to use it, then what does the SAN-SDK need to connect with a REST API?
Keep in mind that I’m an automation specialist, not a TI guy so all of this is a whole new world to me.
Hi, I’m trying to do exactly this, but I’m not able to get the users normal contact info.
I don’t want to use the slack information, but instead use the regular SMS contact field.
Do you have any pointers to how to go about that ?
I’m able to call a rest api with all the alarms, but I just can’t figure out how to get the SMS info from the users on the pipeline.
The Slack example uses a custom contact type. If you just want to use the built-in SMS number, use the built-in SMS contact type:
com.inductiveautomation.ignition.common.user.ContactType#SMS
Thank you so much - that helped a lot.
