Module generator exception during clean build
I'm following the getting started documents. running gradlew.bat clean build in ignition-module-tools\generator throws the following exception.
C:\Users\osk\eclipse-workspace\ignition-module-tools\generator>gradlew.bat clean build
Downloading https://services.gradle.org/distributions/gradle-7.6-all.zip
...............10%................20%................30%................40%...............50%................60%................70%................80%...............90%................100%
Welcome to Gradle 7.6!
Here are the highlights of this release:
 - Added support for Java 19.
 - Introduced `--rerun` flag for individual task rerun.
 - Improved dependency block for test suites to be strongly typed.
 - Added a pluggable system for Java toolchains provisioning.
For more details see https://docs.gradle.org/7.6/release-notes.html
Starting a Gradle Daemon (subsequent builds will be faster)
Type-safe project accessors is an incubating feature.
> Task :generator-cli:kaptGenerateStubsKotlin FAILED
e: java.lang.IllegalAccessError: superclass access check failed: class org.jetbrains.kotlin.kapt3.base.javac.KaptJavaCompiler (in unnamed module @0x67700c2b) cannot access class com.sun.tools.javac.main.JavaCompiler (in module jdk.compiler) because module jdk.compiler does not export com.sun.tools.javac.main to unnamed module @0x67700c2b
        at java.base/java.lang.ClassLoader.defineClass1(Native Method)
        at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1023)
        at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:150)
        at java.base/java.net.URLClassLoader.defineClass(URLClassLoader.java:524)
        at java.base/java.net.URLClassLoader$1.run(URLClassLoader.java:427)
        at java.base/java.net.URLClassLoader$1.run(URLClassLoader.java:421)
        at java.base/java.security.AccessController.doPrivileged(AccessController.java:714)
        at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:420)
        at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:592)
        at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525)
        at org.jetbrains.kotlin.kapt3.base.KaptContext.<init>(KaptContext.kt:68)
        at org.jetbrains.kotlin.kapt3.KaptContextForStubGeneration.<init>(KaptContextForStubGeneration.kt:40)
        at org.jetbrains.kotlin.kapt3.AbstractKapt3Extension.contextForStubGeneration(Kapt3Extension.kt:297)
        at org.jetbrains.kotlin.kapt3.AbstractKapt3Extension.analysisCompleted(Kapt3Extension.kt:175)
        at org.jetbrains.kotlin.kapt3.ClasspathBasedKapt3Extension.analysisCompleted(Kapt3Extension.kt:106)
        at org.jetbrains.kotlin.cli.jvm.compiler.TopDownAnalyzerFacadeForJVM$analyzeFilesWithJavaIntegration$2.invoke(TopDownAnalyzerFacadeForJVM.kt:115)
        at org.jetbrains.kotlin.cli.jvm.compiler.TopDownAnalyzerFacadeForJVM.analyzeFilesWithJavaIntegration(TopDownAnalyzerFacadeForJVM.kt:125)
        at org.jetbrains.kotlin.cli.jvm.compiler.TopDownAnalyzerFacadeForJVM.analyzeFilesWithJavaIntegration$default(TopDownAnalyzerFacadeForJVM.kt:99)
        at org.jetbrains.kotlin.cli.jvm.compiler.KotlinToJVMBytecodeCompiler$analyze$1.invoke(KotlinToJVMBytecodeCompiler.kt:264)
        at org.jetbrains.kotlin.cli.jvm.compiler.KotlinToJVMBytecodeCompiler$analyze$1.invoke(KotlinToJVMBytecodeCompiler.kt:55)
        at org.jetbrains.kotlin.cli.common.messages.AnalyzerWithCompilerReport.analyzeAndReport(AnalyzerWithCompilerReport.kt:115)
        at org.jetbrains.kotlin.cli.jvm.compiler.KotlinToJVMBytecodeCompiler.analyze(KotlinToJVMBytecodeCompiler.kt:255)
        at org.jetbrains.kotlin.cli.jvm.compiler.KotlinToJVMBytecodeCompiler.compileModules$cli(KotlinToJVMBytecodeCompiler.kt:101)
        at org.jetbrains.kotlin.cli.jvm.compiler.KotlinToJVMBytecodeCompiler.compileModules$cli$default(KotlinToJVMBytecodeCompiler.kt:60)
        at org.jetbrains.kotlin.cli.jvm.K2JVMCompiler.doExecute(K2JVMCompiler.kt:157)
        at org.jetbrains.kotlin.cli.jvm.K2JVMCompiler.doExecute(K2JVMCompiler.kt:52)
        at org.jetbrains.kotlin.cli.common.CLICompiler.execImpl(CLICompiler.kt:94)
        at org.jetbrains.kotlin.cli.common.CLICompiler.execImpl(CLICompiler.kt:43)
        at org.jetbrains.kotlin.cli.common.CLITool.exec(CLITool.kt:101)
        at org.jetbrains.kotlin.incremental.IncrementalJvmCompilerRunner.runCompiler(IncrementalJvmCompilerRunner.kt:477)
        at org.jetbrains.kotlin.incremental.IncrementalJvmCompilerRunner.runCompiler(IncrementalJvmCompilerRunner.kt:127)
        at org.jetbrains.kotlin.incremental.IncrementalCompilerRunner.compileIncrementally(IncrementalCompilerRunner.kt:366)
        at org.jetbrains.kotlin.incremental.IncrementalCompilerRunner.compileIncrementally$default(IncrementalCompilerRunner.kt:311)
        at org.jetbrains.kotlin.incremental.IncrementalCompilerRunner.rebuild(IncrementalCompilerRunner.kt:110)
        at org.jetbrains.kotlin.incremental.IncrementalCompilerRunner.compileImpl(IncrementalCompilerRunner.kt:200)
        at org.jetbrains.kotlin.incremental.IncrementalCompilerRunner.compile(IncrementalCompilerRunner.kt:75)
        at org.jetbrains.kotlin.daemon.CompileServiceImplBase.execIncrementalCompiler(CompileServiceImpl.kt:625)
        at org.jetbrains.kotlin.daemon.CompileServiceImplBase.access$execIncrementalCompiler(CompileServiceImpl.kt:101)
        at org.jetbrains.kotlin.daemon.CompileServiceImpl.compile(CompileServiceImpl.kt:1739)
        at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
        at java.base/java.lang.reflect.Method.invoke(Method.java:580)
        at java.rmi/sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:360)
        at java.rmi/sun.rmi.transport.Transport$1.run(Transport.java:200)
        at java.rmi/sun.rmi.transport.Transport$1.run(Transport.java:197)
        at java.rmi/sun.rmi.transport.Transport.serviceCall(Transport.java:196)
        at java.rmi/sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:598)
        at java.rmi/sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:844)
        at java.rmi/sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.lambda$run$0(TCPTransport.java:721)
        at java.base/java.security.AccessController.doPrivileged(AccessController.java:400)
        at java.rmi/sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:720)
        at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144)
        at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642)
        at java.base/java.lang.Thread.run(Thread.java:1570)
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':generator-cli:kaptGenerateStubsKotlin'.
> A failure occurred while executing org.jetbrains.kotlin.compilerRunner.GradleCompilerRunnerWithWorkers$GradleKotlinCompilerWorkAction
   > Internal compiler error. See log for more details
* Try:
> Run with --stacktrace option to get the stack trace.
> Run with --info or --debug option to get more log output.
> Run with --scan to get full insights.
* Get more help at https://help.gradle.org
Deprecated Gradle features were used in this build, making it incompatible with Gradle 8.0.
You can use '--warning-mode all' to show the individual deprecation warnings and determine if they come from your own scripts or plugins.
See https://docs.gradle.org/7.6/userguide/command_line_interface.html#sec:command_line_warnings
BUILD FAILED in 4m 31s
19 actionable tasks: 19 executed
What version of Java is Gradle using?
Looks like version 22.0.1
Yeah, don't do that. Use Java 17.
thanks, that seems to have worked
@paul-griffith I seem to be getting the same build failure:
❯ ./gradlew clean build
avac.KaptJavaCompiler (in unnamed module @0x10135536) cannot access class com.sun.tools.javac.main.JavaC
        at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1026)
        at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:595)
        at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:528)
t:40)
297)
06)
Compiler.kt:255)
lerRunner.kt:477)
lerRunner.kt:127)
kt:110)
ner.kt:200)
kt:75)
.kt:625)
iceImpl.kt:101)
ava:103)
721)
        at java.base/java.lang.Thread.run(Thread.java:1575)
* What went wrong:
* Try:
BUILD FAILED in 1s
20 actionable tasks: 20 executed
Using Java 17:
❯ ./gradlew -V
Gradle 7.6
Build time:   2022-11-25 13:35:10 UTC
Revision:     daece9dbc5b79370cc8e4fd6fe4b2cd400e150a8
Kotlin:       1.7.10
Groovy:       3.0.13
Ant:          Apache Ant(TM) version 1.10.11 compiled on July 10 2021
JVM:          17.0.14 (Arch Linux 17.0.14+7)
OS:           Linux 6.13.4-arch1-1 amd64
> Task :help
Welcome to Gradle 7.6.
To run a build, run gradlew <task> ...
To see a list of available tasks, run gradlew tasks
To see more detail about a task, run gradlew help --task <task>
To see a list of command-line options, run gradlew --help
For more detail on using Gradle, see https://docs.gradle.org/7.6/userguide/command_line_interface.html
For troubleshooting, visit https://help.gradle.org
BUILD SUCCESSFUL in 260ms
1 actionable task: 1 executed
Any ideas?
Does java --version also indicate 17?
Yes it does:
❯ java --version
openjdk 17.0.14 2025-01-21
OpenJDK Runtime Environment (build 17.0.14+7)
OpenJDK 64-Bit Server VM (build 17.0.14+7, mixed mode, sharing)
:man_shrugging:
Do you have a global gradle.properties telling it to use a different Java version or something?
I just did a clean build using the current published version and it worked on mine; the illegal reflective access happens but is allowed, because it's not enforced on Java 17:
~/Projects/ignition-module-tools/generator git:[master]
./gradlew -V
Gradle 7.6
Kotlin:       1.7.10
Groovy:       3.0.13
JVM:          17.0.13 (Azul Systems, Inc. 17.0.13+11-LTS)
OS:           Mac OS X 15.3.1 aarch64
Starting a Gradle Daemon, 1 busy Daemon could not be reused, use --status for details
> Task :help
BUILD SUCCESSFUL in 13s
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.jetbrains.kotlin.kapt3.util.ModuleManipulationUtilsKt (file:/Users/pgriffith/.gradle/caches/modules-2/files-2.1/org.jetbrains.kotlin/kotlin-annotation-processing-gradle/1.7.10/e1d645a739463b61ce1980f67068d8ab9b16fef5/kotlin-annotation-processing-gradle-1.7.10.jar) to constructor com.sun.tools.javac.util.Context()
WARNING: Please consider reporting this to the maintainers of org.jetbrains.kotlin.kapt3.util.ModuleManipulationUtilsKt
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
BUILD SUCCESSFUL in 34s
39 actionable tasks: 39 executed
I finally figured out gradle was using my java 11 environment no matter what I set JAVA_HOME and CLASSPATH to (and no matter what ./gradlew -V reported). I had to uninstall the jre11-openjdk package from my system. This got me past this particular failure condition.
SIDE NOTE: After that I started getting an error about the gradle version - it was using gradle 8 despite ./gradlew -V reporting gradle 7.6. So then I did "sdk install gradle 7.6" and got a successful build. Not sure why the documentation says to install gradle 8.1.1:
./gradlew means you're using the gradle "wrapper", which installs itself; I don't know what issue you were getting but it shouldn't be related to having a particular version of Gradle hard-installed on your system.
I'm also not sure what documentation you're looking at there.
The SDK manual doesn't dictate a Gradle version:
Interesting...
So If you follow that link you just provided, and then select "Environment Setup" from the menu on the left, you will see the gradle 8.1.1 reference. I apparently don't understand how all of this is supposed to work.
Yeah, I think that was just a tech writer or somebody taking instructions they were given too literally. The exact Maven/Gradle version doesn't particularly matter, as long as it's not significantly too old/new to be incompatible with our plugins, if you're choosing to use them.
Got it. Thank you for helping me work through this! I have some things to learn about Java tooling/workflow.
