I created a new module in the marketplace and I load it in the Ignition Gateway. This module is a module with a mongodb jar driver.
This is my module in ignition:
Name Version License Status
MongoDB Driver 2.9.1 (b0) Free Loaded
I created a script in the value changed of one tag:
from com.mongodb import Mongo
from com.mongodb import BasicDBObject
But I have this error:
Value Changed Error executing script.
File "<tagevent:valueChanged>", line 16, in valueChanged
ImportError: No module named mongodb ERROR
This error comes out ONLY in the value changed of one tag and in global/shared script.
I tried also in the shared script but I have the same error (I enclose a picture)
I tried to run the same script in the "Script playgroud"in the designer and it works without any problem.
I tried also to create one project script with the same code and call it in a Window with a button and it works.
It seems that the problem is only in the value changed of the tag and in the shared script.
Can you help me?
Thanks,
Andrea
