I try to obtain absolute file path of a config resource but it seems not possible ?
I’m probably missing something, or maybe it’s intentional, but the API only exposes logical data and hides the actual file system hierarchy.
When I create or find the resource, from the resource object, I can't obtain the absolute folder path.
ResourceType type = new ResourceType(Constantes.MODULE_ID,"license");
Optional<Resource> resourceFind = context.getConfigurationManager().getConfigCollection().getSingletonResource(type);
resourceFind.get()
My Resource contain a file and I need to pass the absolute folder of this file when calling an external library.
Mostly intentional/you ideally shouldn't need to resolve exact file paths. There's a static utility method, but it's considered implementation rather than API so not easily accessible to you.
Technically the correct logic would be to check com.inductiveautomation.ignition.common.SystemProps#CONFIG_DIRECTORY; if it's not present then you resolve:
context
.getSystemManager()
.getDataDir()
.toPath()
.resolve("config/resources")
.toAbsolutePath()
Then resolving an explicit resource under that relies on reversing the resource type / folder path encoding scheme.
A safer/saner approach might be to copy the data you need into a module-specific temp directory and point the external lib there.
Thanks a lot, that make sense.
Using Config Resources was convenient for me to store data synchronized between master/backup gateway...
"scope": "A",
"version": 1,
"restricted": false,
"overridable": true,
"files": [
"verification.txt",
"config.json"
"attributes": {}
