I just started tinkering with this now, haven’t fully grasped how to use it yet so correct me if this is already possible …
I think it’d be pretty nifty to, instead of using …
query.addTable("Table");
query.addColumn("Column1");
query.addColumn("Column2");
// etc
… be able to use …
query.addTable("Table").addColumn("Column1").addColumn("Column2");
… kind of like a fluent API type deal.
Yeah, I like this pattern as well. I don’t really see any reason it wouldn’t work on DBQuery other than that the author didn’t write it that way
… no worries, it was just on my mind while I was messing with it, figured I’d just put it out there. I like the idea of being able to break down a query programatically, pretty nifty.
Thanks!
I modified the add* methods to return ‘this’ so you can chain the calls together. You’ll see it in the 7.4 final release.
[quote=“Kevin.Herron”]I modified the add* methods to return ‘this’ so you can chain the calls together. You’ll see it in the 7.4 final release.[/quote]Sweet! I can scrap the DBQueryBuilder class I’ve got now
Thanks!
