I’m developing a SDK module to add a component to the Vision module.
This component has a JTextField. What I want is when I write some text in this field, the Text property change to the text I wrote.
What I’ve done is that when I write text in the Text property, the text into JTextField change.
You might try adding a listener to the text field.
You also may want to do some reading about how text fields and Java Swing in general works.
