Does anyone have a nice way to get code signing secrets into a Gradle container for CI building of their module?
Getting the files in is easy. Getting keystorePassword and certPassword in is stumping me. The stupid . in their project property names makes them unusable as far as I can tell via the ORG_GRADLE_PROJECT_xxx environment variables.
I thought I was going nuts but I eventually found this blog post where someone else is struggling with the same thing. His best solution would require I make one big GRADLE_OPTS environment variable with both passwords in it.
I feel like there must be a better way I’m missing.
(EDIT: Yeah, I could just make a script file in the container and use that as my launch point, using that script to pull the secrets into the command line… I’m probably overthinking this, but I still feel like it’s a weird weakness in the setup to not support the passwords directly from secret files or environment variables…)
I did it via GHA in Ignition Extensions... I don't recall the env vars in particular giving me trouble, only the annoyance of having to b64 encode the files since GHA secret management only supports strings.
I added a secret file to my ci pipeline. It uses GitLabs secure files and then I had to download the files.
Pretty easy and secure.
Yeah, Github and GitLab and Bitbucket all have nice ways of dropping it in their respective CI definition files.
I should’ve mentioned that I was also trying to find a way to make it work with docker-compose so that our developers wouldn’t need to struggle with setting up development environments or having them get out of sync or conflict with other work.
But @bmusson had a subtle difference in his: he pushed secrets into the gradle.properties file in the home directory, which let them be used without conflicting with any gradle.properties in the source directory!
So, voila:
services:
gradle-env:
build:
context: .
dockerfile_inline: |
FROM gradle:7-jdk11
RUN ln -s /var/run/secrets/gradle-properties /home/gradle/.gradle/gradle.properties
user: gradle
secrets:
- codesign-certificate
- codesign-pfx
- gradle-properties
volumes:
- ./:/home/gradle/project
working_dir: /home/gradle/project
command: ./gradlew build
secrets:
codesign-certificate:
file: ./secrets/codesign.cer
codesign-pfx:
file: ./secrets/codesign.pfx
gradle-properties:
file: ./secrets/gradle.properties
That works and I think it’s relatively clean.
Yes, that will re-build the damn gradle environment every time you let it close and re-start. If a developer is doing lots of iterations it would be more useful to run docker compose run gradle-env bash and then they can run gradlew over and over more efficiently.
I mean, at that point you can also just pass arbitrary property overrides directly into the gradle command line, no need to stop in environment variables on the way
Yeah, some of my stumbling was my (unnecessary) insistence on making it so just running ./gradlew build without any parameters would work.
