Module upgrade from 7 to 8: "Can't instantiate page using constructor"
This is a public service announcement for anyone that is upgrading a module to work with Ignition 8 and they have a gateway component with a settings page.
If you receive an Internal error when you navigate to your settings page, and the Ignition logs have this error:
jvm 1    | E [o.a.w.DefaultExceptionMapper  ] [20:05:24]: Unexpected error occurred
jvm 1    | org.apache.wicket.WicketRuntimeException: Can't instantiate page using constructor 'public com.inductiveautomation.ignition.gateway.web.pages.Config(org.apache.wicket.request.mapper.parameter.PageParameters)' and argument 'path=[seeq.hub]'. Might be it doesn't exist, may be it is not visible (public).
then you may need to change the following code:
Ignition 7.x-era constructor in your XxxxSettingsPage.java:
    public SeeqSettingsPage(final IConfigPage configPage) {
        super(configPage, null, new LenientResourceModel("Seeq.nav.settings.panelTitle"),
                ((GatewayContext) Application.get()).getPersistenceInterface().find(SeeqSettingsRecord.META, 0L));
New Ignition 8.x-era constructor in your XxxxSettingsPage.java:
                ((IgnitionWebApp) Application.get()).getContext().getPersistenceInterface()
This was a needle in the haystack for me, hope it helps others!
