Modules not compatible with macOS with Apple M1 Pro
Hello,
I'm finding it increasingly frustrating that, whether I use the sample module file or create a new one on my MacBook with an Apple M1 Pro chip, I can upload the module to Ignition but it never transitions to ACTIVE mode. When I try to enable it, I get an error with no detailed explanation. Do you have any idea why this might be happening? I feel like I've hit a brick wall. Would appreciate any help as I do not want to install Virtual machine on my mac for it.
Pretty much all of us who work on MacOS are using docker as our test platform, and that has no issues at all with modules. I also have built modules with all the standard tooling on my M4 MBP and run them on a local install with no issues either.
I would just use docker, and if the symptoms persist, show us the errors.
David thanks for the reply. I did not see any docker version of ignition so I am assuming you are using an image from the marketplace? can you please eloborate this will be big a help.
Also I am seeing AppIgnition as one of the docker extension, is this what you are referring?
Not a bad practice, but on the flip side many of the IA developers use Apple Silicon Macs and do not use Docker for development. You haven't provided enough/any details or code.
Thanks a lot.
I am using MAcos 26.0.1 with Apple M1 Pro. I am using Gradle within IntelliJ IDE and built the first plugin using “ignition-module-tools” and built another one using the generator. I can see both modules in the list but in “disable” state. When trying to “Enable” them gets an error but no detail even I set the logging to “DEBUG” level. My colleague using Windows has no issue at all. This is where I am stuck
Check the actual system logs, either via the logging web interface or the wrapper.log file on disk. It should be pretty clear what the failure is.
