I am unable to translate a mutli line text on a momentary button with html code. If I use the text as a single line with no html code, it works just fine. I can translate a multi line navigation button without issue. Has anyone been able to solve this situation?
Since <html> is part of the string, it won’t match a key, unless you also put <html> in the translation. Which can be a pain, if you have a lot of them. Try an expression:
'<html>' + translate('The text you wish to translate')
I was able to put “html” on my navigation buttons without an issue during translation. This scenario is specific to momentary buttons not using the translation.
It also applies to other components, labels being one of them.
Either I am not implementing your expression suggestion correctly, or it functions the same way as the previous method.
That is how my translation manager looks, but does not function for momentary buttons. I am using ignition 7.9.12
Hmm. I spun up my 7.9.9 server and it works okay. Can you do up a screenshot of your translation manger with the Clear Alarms entry showing?
I have meetings for a few hours, but I can revisit this afterward.
Attached is a window with a momentary button. I set up my translation manager to match the entry you have. Keep in mind that the text must exactly match the key. This may include any extra whitespace (I’ve been hit with that once or twice with spaces at the end of the key). If you find that everything matches okay, you may have to contact support.
Translate_test_JC_Translate_Test_2019-12-04_1019.proj (4.0 KB)
Tried opening your project on our server, same issue of the text not displaying when translated. This points to some issue on our server. Thank you for the help, will update if I find a resolution.
