More Granular Gateway Security Control
Is there a way to control more granular access within the Ignition Gateway? For example, allowing users the ability to create or edit Device Connections but not allowing access to other sections under the Config menu?
We are looking for ways to have specific members have access to create connections to devices such as PLCs or other OPC UA devices but not allow them access to get into the more specific Gateway settings or security type of menus.
No, sorry. If you need that sort of thing, use Ignition's APIs to expose the desired operations through a Perspective or Vision UI, where you can apply roles and permissions as you see fit.
