Any ideas as to what these mean and how they can be tracked down?
“Cannot locate member for id 7c66988d-3e2b-4b66-a15d-a27194c80414.df94c04d-08d7-458f-9466-21369efe60a0”
Logger is CustomTagConfigurationUtils
Cheers,
Oscar.
Cheers,
Oscar.
Bumping this.
The log entries appear when I configure a transmitter in the MQTT Transmission module; MQTT traverses through the Tag Path provided in the transmitter configuration and it starts producing the log entries.
Any ideas as to what these entries mean and how do I get rid of them?
Thanks,
Oscar.
Please expand the details for one of those log entries and paste it here. Please use triple-backquote formatting (on a line above and again below) so the pasted material is readable.
Here’s an portion of the logger after enabling DEBUG on the logger and refreshing the MQTT Transmission control bit:
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: localMembers(false) = 37
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: localMembers(true) = 37
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Enabled, Enabled, [1, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Amps/Hi Hi, Hi Hi, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Volts/Low Low, Low Low, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Volts/High, High, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Volts/Hi Hi, Hi Hi, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: VoltageSPPICS, VoltageSPPICS, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Amps/Low, Low, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Amps/High High - Low Low Precent, High High - Low Low Precent, [0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: VoltageSP, VoltageSP, [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Volts, Volts, [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Amps/Lo, Lo, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Volts/Raw Value, Raw Value, [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Volts/High High, High High, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Amps/Low Low, Low Low, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Amps, Amps, [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Amps/High, High, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Volts/Capacity, Capacity, [41, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Volts/High High - Low Low Precent, High High - Low Low Precent, [0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: AmperageSPPICS, AmperageSPPICS, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Volts/Value, Value, [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Volts/Hi, Hi, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Amps/High High, High High, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Volts/Lo Lo, Lo Lo, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Amps/Value, Value, [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Volts/High - Low Precent, High - Low Precent, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Status, Status, [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm/Volts/Low, Low, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Amps, Amps, [null, Unknown, Wed Nov 14 10:32:28 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: definition
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: localMembers(false) = 0
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: localMembers(true) = 0
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: AmperageSP, AmperageSP, [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: PICSAlarm, PICSAlarm, [null, Unknown, Wed Nov 14 10:32:28 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Volts, Volts, [null, Unknown, Wed Nov 14 10:32:28 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | W [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Cannot locate member for id 74ffaa00-5e88-49ca-9146-662a83a9d2f3.54d023e4-867b-4420-8b25-a5af1772ff00
INFO | jvm 2 | 2018/12/04 09:01:55 | W [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Cannot locate member for id 74ffaa00-5e88-49ca-9146-662a83a9d2f3.470dc359-feca-4f8e-ab44-a848e4fdde07
INFO | jvm 2 | 2018/12/04 09:01:55 | W [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Cannot locate member for id 03639061-dc58-478f-b01c-d2ddeab21705.470dc359-feca-4f8e-ab44-a848e4fdde07
INFO | jvm 2 | 2018/12/04 09:01:55 | W [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Cannot locate member for id 03639061-dc58-478f-b01c-d2ddeab21705.54d023e4-867b-4420-8b25-a5af1772ff00
INFO | jvm 2 | 2018/12/04 09:01:55 | W [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Cannot locate member for id 4f13ce7f-4307-4548-80af-7f3466047633.54d023e4-867b-4420-8b25-a5af1772ff00
INFO | jvm 2 | 2018/12/04 09:01:55 | W [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Cannot locate member for id 54d023e4-867b-4420-8b25-a5af1772ff00
INFO | jvm 2 | 2018/12/04 09:01:55 | W [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Cannot locate member for id 94114d8c-b023-4fb1-9418-010f6118df5d.54d023e4-867b-4420-8b25-a5af1772ff00
INFO | jvm 2 | 2018/12/04 09:01:55 | W [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Cannot locate member for id c4667440-8e1a-41d3-a877-4973945e56c9.54d023e4-867b-4420-8b25-a5af1772ff00
INFO | jvm 2 | 2018/12/04 09:01:55 | W [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Cannot locate member for id cb877aa5-c184-4439-9007-c32ba886f3f8.54d023e4-867b-4420-8b25-a5af1772ff00
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: parent type = Sensor
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: parent members(true) = 8
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: parent members(false) = 8
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: member - qualified name: Capacity
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: folderUID: null
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: UID: 1d382ba6-33b9-4003-a8a3-1a76964ac163
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: type: [default]Plating/HZ/Sensor
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag name: Capacity
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag value: [41, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag type: DB
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: member - qualified name: Hi Hi
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: UID: 5c582106-1ade-42be-a113-c6c8c93fe1a4
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag name: Hi Hi
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag value: [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: member - qualified name: Value
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: UID: 470dc359-feca-4f8e-ab44-a848e4fdde07
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag name: Value
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag value: [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: member - qualified name: Raw Value
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: UID: 8b238bb0-7e9a-4d02-8d2a-918115494255
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag name: Raw Value
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag type: OPC
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: member - qualified name: Lo
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: UID: 54511a94-717c-4689-b84b-a33d2ef8bc7a
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag name: Lo
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: member - qualified name: Lo Lo
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: UID: 3130851e-e185-432e-bce5-61b3dd4cadff
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag name: Lo Lo
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: member - qualified name: SP
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: UID: c4be5229-5e23-4be4-b9af-921d5051dfa7
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: tag name: SP
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: UID: 51a4d1ba-d113-4150-b403-001b77942da6
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: localMembers(false) = 8
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: localMembers(true) = 8
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Capacity, Capacity, [41, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Hi Hi, Hi Hi, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Value, Value, [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Raw Value, Raw Value, [null, Unknown, Tue Dec 04 07:58:22 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Lo, Lo, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Lo Lo, Lo Lo, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: SP, SP, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Hi, Hi, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Tin Plate 2/Temperature/Hi Hi, Hi Hi, [0.0, Good, Wed Nov 14 10:32:35 CST 2018]
INFO | jvm 2 | 2018/12/04 09:01:55 | D [c.c.m.c.u.CustomTagConfigurationUtils] [15:01:55]: Member: Nickel Plate 1/DO Temp, DO Temp, [null, Unknown, Wed Nov 14 10:32:28 CST 2018]
Well, that’s coming from the Cirrus Link module itself – you’ll have to ask them to decipher this.
@oscar.salcedo - sorry to revive this thread, but have just come across this ourselves. Did you get any word back from Cirrus Link on this?
I believe it was an issue with the MQTT module version. Are you running the latest release? Otherwise, you could post in the Cirrus Link forums: https://forum.cirrus-link.com/
Cheers!
Oscar.
