Hi, I write to ask for some help, I need to put more than one database in a Line Graph Component in the same plot if can name like this, the area for the grafic, inside my Report Viewer but I don’t find how to do it.
Can you help me with my problem?
I will Appreciate it.
Thanks for all
Carito
All you have to do is go into the chart customizer (right click and select customizers) and add another dataset. Once you have two datasets you can bind them to different SQL queries to tag history bindings. That way you will show data from two sources on the same plot. The dataset properties tab allows you to configure which axes the datasets go inside of. Hope this helps you get started.
