I am new to Ignition. I am in development for a new project. This will eventually deploy to all new sites.
Here is the scenario:
I want to populate motors status on a table format.
Example table layout:
Column 1-5 (Motor number, Motor status, Motor speed, Motor temperature, Motor current (A))
I have total of N number motors. It could be 70 or 100 or 150 motors. Depends on the site/plant layout. Base on the setup, the table will have N rows. like, if I have 100 motors specified, the table will have 100 rows. This will give the operator a quick high level summary on the motor status. If operator double clicked on row 3, then a popup window will display Motor 3 additional detail status/information on the Motor 3, like alarms, motor specs and trend…etc.
Any idea where I can get a jump start and put this together? Power table and example codes…etc
Much appreciated.
I would take a look at the following links. You should be able to configure something similar, but instead of using the button’s actionPerformed event, use the tables, on Double Click Extension.
Thanks grietveld for your quick respond.
My issues is on the first part. Populate N number motor status on the table format. I’ve been looking at the power table but just can’t find a way where to begin. looking for some quick examples if any.
