I have an object which is comprised of a number of other groupings and containers. I want to have the cursor to change when it is over the object or specific sub-objects to indicate the object is controllable. It works fine in designer, but when I try it in Staging or Published, it does not work.
I then tried to change it via the mouse entered and mouse exit events. Still did not work when in Staging or published.
The last thing I tried was changing the mouse over text on the entire object, with the same results.
I have version 7.3.3 (b570).
Thanks.
