Mouse Over Color Fill
I have a floor plan that has departments, or zones, that can be selected to drill down into that area with another screen. I have svg shapes that determine the zones. I’m trying to get the svgs to be transparent until you mouse over them, which would set the color to a semi-transparent one. I’ve tried setting it using these, but no luck. Am I going about this wrong, or is my script just lacking? I’m using the mouseEntered event handler in scripting. thanks
event.source.fillPaint = "255,255,255"
event.source.fillPaint = java.awt.toColor("255,255,255")
You might want to try system.gui.color() to return a color instead of assigning a string.
https://docs.inductiveautomation.com/display/DOC79/system.gui.color
Thanks, I actually found this right before you posted. However, the link was perfect to fill me in on using the alpha argument as well for the transparency. Thanks
event.source.fillPaint = system.gui.color(255,255,255,100)
for transparent white.
Thanks Nick
